I've decided to get the Xtar H1 headlamp set up, after much research on the forums here. I'm not familiar with the 14500 rechargeable Lithium battery at atll, other than seeing that it will push the Xtar H1 to anther level.
I see that I can get the 14500 in several make ups.
mAH ratings-do I need to concern myself with this? I kinda understand that as the number goes up, the battery will last longer?
Voltage rating-the Xtar H1 will except .9-4.2v, so is there a best voltage for this OR any light. I know that I'll be using it in the cold weather to hunt. I think I read that lower voltage batteries work better in cold? Peak & average voltages are mentioned on these battery descriptions also...I'm really clueless about this voltage thing, can you tell?
Brand-is there a best brand?
I've got a couple of rechargers, will they be fine for these 14500? Powerex recharger for AA AAA, not to much in the way of description on the bottom, INPUT dc 18v 1000ma. My other recharger, a LA Crosse Technology charger, has "Accus 300-3000mAH & DC 3V" on it. DO I need another recharger as well? I'm assuming yes? If so, is there a recommended recharger for the 14500?
Protected OR unprotected cells?! I'm assuming getting protected will just make it easier, as I'm also not sure about this issue
Any help would be nifty and appreciated...thanks, Kevin
