Hi John,
I'm looking forward to that how-to. Thanks in advance.
These M-series weaponlights are a real bargain and a great cost-effective alternative to the current Surefire weaponlight offerings. With a little work and with the right components they can approximate, or, in some cases, exceed their performance.
As an aside, take a walk over to the TnC subforum in Custom and Modified. I've been giving a lot of thought to the M-series given their availability and adaptability. One of the problem areas with the M-series when upgrading them to LED is the LU60 adaptor collar. I'm working with Chris to develop an updated variant of the collar that will accept current LED drop-ins without modification. Chime in their if you have an interest. It would help with the project momentum
. In case it interests you, as well, Barry at PrecisionWorks has found a way to work-hold M-series bodies to bore them to use 18mm cells.
I'm really looking forward to a bored M-series with the new LU60.
When everything comes together, I'm going to try running a 3.15A de-domed XP-G2 drop-in from Wayne. If the switch can digest that current, I might try something hotter.:devil:
