9AN's tailcap spring
nuw040
9AN\'s tailcap spring
What is tailcap spring? and where is it or which part of 9AN?
Please help, THANK YOU
bfm
Bostom
Re: 9AN\'s tailcap spring
It is the spring inside the tail cap, visible if you unscrew the tail cap, that keeps tha batteries from rattling around and provide the negative contact.
ygbsm
NY
I removed and replaced mine by simply pulling it out of the tailcap.
ToddM
NV
yep, when you remove the tailcap and look inside it, it's obviously a spring maybe 3/8" in dia. and oh 5/8" long, also the only part easily removeable from the lock out tailcap.
If your looking to get it replaced since surefire had some issues with some of them and reportedly the new spring increases voltage to the bulb by as much as 20% I hope you have better luck than I have. I've been sent wrong parts twice now in attempting to get the new spring since October. I'm waiting for their third attempt. It hasen't cost me anything but when it takes a month or more to get each shipment and the first two are wrong it's less than a positive experience.
Todd
Tombeis
OHIO, U.S.A.
Todd:
Steve Ryan at Surefire replaced the entire tailcap with new springs in two of my 9AN's.
I could see the improvement in the whitness of the light.
Now, if we could only get a battery fix...
ToddM
NV
Tombeis,
Yeah that's who I've been talking with to get the spring. My guess is somewhere from Steve to who ever actually ships the parts things get messed up.
The first time I got what I thought to be a 9N tailcap assembly but it's too small, must be for like a old 8X, the second time all I got was a spring but it's not the 9AN spring it's much larger in dia. like 1".
So now I'm waiting for the third try, hopefully third time is the charm. I don't mind the battery fix too much, I have 6 2200 mah packs I made some time ago. Though I wouldn't mind having the 6 defective packs replaced with something that actually works.
Todd
