PCC
I'm offering to the CPF community custom made flat acrylic or polycarbonate round lenses. The main intent here is to offer replacement lenses for Surefire or any other flashlight manufacturer who used pressed in lenses, but, also as replacement lenses for old and outdated flashlights that you cannot get a replacement lens for. These are made to order and are offered in three different materials in thicknesses from 1/16" to 1/4". Clear acrylic is available up to 1" thick (the limit to what I can cut using my mill). I can cut lenses up to 2.5" in diameter (Looks like I can cut lenses up to about 3.5", approximately 90mm) All prices are delivered to the USA and Canada. International purchases please add $5 to cover the added shipping costs.
Clear acrylic - available in 3/32", 1/8", 3/16", 1/4", 3/8", 1/2", 3/4", and 1" thicknesses.
Acrylic is a very clear material, even at 2" thick, that is fairly easy to work with and offers the best light transmission possible of the materials listed here (92% at 6mm thick, manufacturer's specs). It does scratch easily, however, as all plastics do. Acrylic lenses tend to crack when impacted or folded. In the thinner materials (1/4" thick or less) up to 2" in diameter one lens will be $4, $6 for two. For larger diameters please add $1 to each of the prices listed. For lenses thicker than 1/4" please contact me via PM.
Abrasion Resistant (AR) acrylic - available in 1/8" and 1/4" thicknesses.
AR acrylic offers the clarity of acrylic but adds an abrasion resistant coating that will prevent most of the fine scratches that you get from normal cleaning of the lens. These lenses will scratch if an abrasive material comes into contact with it so don't expect miracles. I use single-sided AR coated acrylic (AR1) since the back side of lenses aren't cleaned as often as the front side. I can get double-sided AR coated acrylic (AR2) if you desire. The light transmission is 92% at 1/4" thick (manufacturer's specs) though I expected this to be slightly less due to the AR coating. $5 for one lens or $7 for two up to 2" in diameter. For larger diameters please add $1 to each of the prices listed.
Polycarbonate - available in 1/16", 3/32", 1/8", 3/16" and 1/4" thicknesses.
Polycarbonate is the same lens material that Surefire used in their pressed in lenses for lights like the early Surefire 6, 6P (with pressed in lenses), 8X, 9N, etc. polycarbonate lenses will deform and stretch in an impact, and should not shatter. Polycarbonate lenses do scratch easily, however, and offer about 86% light transmission at 3/32" thick (manufacturer's specs). If you have an old Surefire that has a bubbled or burnt lens that you would like to keep fairly original then this is the material of choice. $4 for one, and $6 for two up to 2" in diameter. For larger diameters please add $1 to each of the prices listed.
Lead times: these lenses are made to order and I don't stock all thicknesses listed. If I have the material in hand I can get a lens or two in the mail in a few days to a week. If I don't have the material in hand it can take up to two weeks, but, if my local plastics supplier doesn't have stock in hand for a certain material in a certain thickness then there's no way to know how long it'll take them to get material to me. They are pretty good at stocking material, however, so this should not be a concern. As of today, October 4, 2013, I have 1/16", 3/32", 1/8" polycarbonate, 1/8" AR acrylic, 3/32" and 1/8" acrylic.
If you supply me with dimensions for a lens and it does not fit I will not be held responsible. If you want to ensure that the lens will fit then I will request that you send me the bezel and I will return it to you with both the replacement and the original lenses for the same prices listed above.
Keep in mind that FlashlightLens.com offers and sells replacement glass and coated acrylic lenses for many flashlight applications. They might offer something that will suit your needs already and I highly recommend that you use their services if you can. If they don't have the right size lens for your application then I'll be more than happy to cut one for you to your specs.
Some lenses I've made:
Link to the Z17 lens that i had made for cland72.
The Surefire 8X on the left has a 3/32" thick acrylic lens while the Pentagonlight X3 on the right has a 1/8" thick AR acrylic lens that has been thinned around the edges to fit (original lens was 1/16" polycarbonate).
