Just an observation (no actual problems encountered) -- but the Streamlight warranty that came with a Protac 2L is stated to be "Limited Lifetime." The exclusions are LED, electronics, and switches (i.e., all the active parts), which are only guaranteed for 2 years. This leaves only the body, head shell, bezel, lens, and reflector to be guaranteed for a "lifetime." But realistically, the only way those passive components will fail is as the result of wear and tear or abuse -- neither of which are covered. So .... why isn't the warranty simply stated to be 2 years, and leave it at that?
Or does Streamlight typically step up and cover all parts for an extended period, as long as the failure was not the result of obvious user damage? Just curious.
