I doubt that any light can do that even with 2AA, it can't be regulated.
Sounds like Ansi with an unregulated boost circuit to me with most of the runtime well below 100 lumens. AA alkalines can run up to aroung 2700mah I believe and at 1.2v that is more like 3.2 watt hours dropping down in power as current increases.Assuming a near perfect 300 lumen per watt LED, a ~2.4 watt hour eneloop would be able to power it at 100 lumens for roughly 7 hours or so. a 2700mAH rechargable AA would be able to do 9.8 hours under ideal conditions. Alkalines right now run around 2 watt hours, so both batteries and LEDs need to get better before that is possible. With current technology topping out at 160 lumens per watt and batteries being what they are, the advertised runtime is being fudged, though probably allowed under ANSI guidelines.
Here is the secret to the "100 lumen for 11 hours" claim. The driver is fully regulated. Perfectly flat as far as I can tell. But once that little red low battery light starts blinking, it only operates in low mode. It will run on low mode for hours like that. So, the "100 lumen for 11 hours" is probably more like 100 lumens for three hours and then 8 hours at 10 lumens. That is technically within the ANSI FL1 but I don't like how it is advertised.
Lumens: | 200 | 200 | 100 | 10 | - |
Runtime (Hours): | - | 1.5 | 11 | 65 |
I found the SSA10 on sale (open box) and picked up some of these for gifts. The UI is great for non-flashaholics. One button for off/on, one button for mode switching, one status light for "recharge the battery please!" Nice and simple.
There is a gentle fade between some of the modes.
The SSA10 is relatively large for a 1xAA light. The body tube has an inside diameter of 17mm. It tapers down towards the bottom and with the spring there is no battery rattle despite the spacious interior. There is exactly enough space to fit a single dollar bill if you fold it in half lengthwise and wrap it around the AA. Maybe it can lego with an SSC10 head?
Here is the secret to the "100 lumens for 11 hours" claim. The driver is fully regulated. Perfectly flat as far as I can tell. But once that little red low battery light starts blinking, it only operates in low mode. It will run on low mode for hours like that. Unfortunately I can't do a full runtime test at the moment. But if I had to guess, I think it will run on low for 8 hours with the warning light. It has already been going for three hours, will update later.
So, the "100 lumens for 11 hours" is probably more like 100 lumens for three hours and then 8 hours at 10 lumens. That is technically within the ANSI FL1 but I don't like how it is advertised.
update: I spoke too soon! At 3.25 hours after the low battery light came on the SSA10 began having trouble. It couldn't operate the main LED and the red LED at the same time, so the main started blinking opposite the red LED. At 3.5 hours the main LED stopped turning on at all.
The final voltage across the cell was 0.80V. The battery for the test was an Eneloop Pro.
I am not sure how this light can do "100 lumens for 11 hours" and I will have to do a real runtime test to find out more. Maybe it does better with alkalines in low-battery mode?
Woods Walker, the SSA10 is still a good light and Jetbeam still makes nice lights. Maybe not WOW WOW WOW grade of lights. But if you're going to shun every manufacturer who has ever published a single misleading specification... Well then you won't ever be buying another flashlight again. They've all done it, intentionally or not.
Also there are makers who don't do this or rather not near that extent (I don't totally take output numbers and runtimes as gospel) so odds are I will be buying another flashlight again. We could run down the list but you know I am right.
