Hi, I have a 12Volt 20 Amp Power supply running 7meter strip LEDs (5630 SMD 24watt per meter) and it works fine.
When adding 12 ohm (Brown,red,black,gold) resistor it dims leds without flikker. I can add up to about 8 resistors in series and lights dim.
Now - I want to buy a 0 - 100 ohm variable resistor to control this and elactronic shops tells me they do not recomend me doing it like that. I must use puls dimmer. I cannot use puls couse this is for photography and you see the flicker clearly in photos.
Am I missing something?
Thank you for your help.
This is what the shop say "I'm sorry but your power requirements make the use of an adjustable resistor too impractical! The only way around this is to use some electronics, unfortunately we do not have something readily available on our shelves to suit your needs. In our case we will have to custom make this for you "
