StorminMatt
I recently got a Solarforce XM-L2 drop-in for my Dereelight Javelin. And there are fitment issues with the center terminal spring on the driver board. Compared to the spring on the XP-E Dereelight module, it is longer and stiffer. It is also cylindrical vs conical, so it can't compress flat. And to make matters worse, the Solarforce module has a deeper pill that hangs down further into the host. All of this is causing fitment and contact issues, and is certainly putting undue strain on the drop-in and batteries. Is it REALLY necessary to run this spring? Given that the longer pill already protrudes into the battery area, could I not just remove the spring and have the top battery directly contact the driver board (like in SO many other lights)?
