I haven't been all that active with this forum lately, but I do still check in here from time to time. As a retired suburban police officer/deputy sheriff turned law enforcement officer in post-retirement quasi federal slot, I am still on a number of forums and get various police magazines. Sometimes, when I run across an article on a police forum or in a magazine, I will post it here for members enjoyment. I do, personally, own an older Streamlight Stinger with a TerraLUX upgrade and work issued me a Streamlight Stinger LED flashlight. I will be the first to admit that the Streamlight Stinger is not the best flashlight that you can buy. On the other hand, it is also not the worst flashlight, either. As I have posted here in the past, many members here know what is best for law enforcement officers with regards to illumination products.
We, as coppers, see similar advice given for other tools of the trade. For example, I have carried a Glock pistol, of one model or another, for the past 20 years. Some firearms buffs will point out that we really should be carrying something else. While that very well may be, I am basically told, as a condition of my employment, that I can carry any sidearm I want, as long as it is a Glock 21SF.
So, to, it goes with motor vehicles. I have been assigned Chevrolet Caprices, Impalas, Ford CVPI, Taurus, Dodge Stratus, Dodge Caravan, etc. over the years, depending on the assignment. Again, car buffs know what is best for us and often suggest to us that we really ought to be driving.
So, with that in mind, I post the URL below and the article. Personally, I do prefer LED over incandescent. I prefer rechargeable over non-rechargeable. Also, I prefer charging in a cradle over other methods for police work. Yeah, I get that removing the batteries and charging in a stand alone charger is probably the better way to go for purists. However, for most coppers, a rechargeable LED with a cradle charger mounted in the vehicle is mighty nice. Perhaps the future will bring more lights, similar to the Pelican 8060, that charge in a cradle , but also can use regular batteries.
Jim
http://www.policeone.com/police-pro...-Why-Id-pick-a-Stinger-flashlight-for-patrol/
During my career, Streamlight Stingers changed how we patrolled and trained, and given my choice of flashlight for patrol, I'd pick a Stinger every time. The Stinger is the perfect-sized torch for a primary light. It's small enough for the patrol officer to keep it on the belt all the time, even when seated in a vehicle.
When an officer needs to manipulate something with a gun in the hand (change magazine, open door), pocket-sized lights were dangled from a cord or strap, with the light flipped out of the way. This meant there was an interruption in light downrange. Meanwhile, techniques with a full-sized light were always cumbersome.
With the Stinger, we trained officers to pin it under the "primary" arm. The officer completed the task and then untucked the light. The length and circumference of the Stinger body is perfect for this technique. It doesn't get in the way of a magazine change, and we learned that the arm tuck also put the spillbeam in a perfect place while writing a ticket. The Stinger literally improved officer safety because the gun was always in the hand and the beam was pointed toward the potential threat.
The Stinger has had a long history with law enforcement. For me, it's a Stinger every time.
New LED Stingers
As LED technology developed, Stingers understandably started coming out in LED versions. The Stinger Classic LED (756662) has the same feel as the original, with a much better Ni-Cd A runtime of 6.75 hours on low power. The torch now puts out 390 lumens/13200 candela on the highest setting. Part of the lens is frosted, throwing a soft-edged floodlight-style beam. Because it uses a C4 LED, it is inherently stronger and the lens/reflector is much more robust than the original.
Streamlight has produced the Stinger DS (Dual Switch) version for a few years. This is similar to the original form factor, with all of the new features plus a tail switch.
What are the new features? Take any later model Stinger. Press the switch once and you get a high beam. Click it twice rapidly and it becomes a strobe. Hold it down and it dims. One can release the switch at the desired brightness. It always defaults to traffic-stop bright when it goes from off to on. Tail switches do the same thing. The switches have a consistent feel and a repeatable, tactical grip; without the need to index with a thumb or finger, a user can turn it on even when wearing gloves.
Here's the confusing part: There is a Stinger DS LED HP (Dual Switch, LED, High Power, 75863) with 350 lumens/56,000 candela and a Stinger DS LED HL (Dual Switch LED High Lumen 75464) with 640 lumens/22,000 candela output. They all take the same chargers, and all Stinger DS models will fit the same accessories. All Stinger Classic models will fit the same accessories. Which one is the one for you?
Choosing Your Stingers
Using the light with the greatest output may sound like the best strategy, but it is better to go with the intended purpose of the light.
If you generally patrol in an area where you need to project a beam at a distance, consider the Stinger DS LED HP. It was designed to throw as far as 473 meters. The beam is concentrated and abrupt and the spillbeam isn't particularly soft, which creates harsh shadows. Rural patrollers, SAR members, and officers assigned to a specific area like a train yard or transit area would like this light.
It is not recommended for officers whose assignment includes a lot of residential searching. Trust me, this beam reflects back at you on a white interior wall.
For general patrol where tactical advantage on traffic stops is critical, the Stinger DS HL is for you. This light will still reach out but it can light up a car interior at a good distance like no other product. I would use this light for any type of search.
For all mounted, two-wheeled, special assignments, and investigations, the Stinger Classic is the one.
About the author
Lindsey Bertomen is a retired police officer and retired military small arms trainer. He teaches criminal justice at Hartnell College in Salinas, California. He has a BS in Criminal Justice and an MS in Online Teaching and Learning. Lindsey has taught shooting techniques for over a decade. His articles on firearms tactics have appeared in print for over a decade. Lindsey enjoys competing in shooting sports, running, and cycling events.
Jim
New LED Stingers
About the author
