I nearly got this mule build just right!
I thought I'd try mounting wires to LED through bottom of star to enable easy
use of different optics nad reflectors. Turned out pretty easy.
Drilled the star.
Notice 3 small solder balls around LED. (as received them)
Ball further away removed easy with a pick. Other 2 stayed. I suppose I should remove with iron?
Tried some heatshrink on end of wires but too thick so used some kapton tape instead.
Lapped the star then soldered wires.
Test fitting to mule sink. The star wants to sit fairly centered.
Solder joints were a bit "blobby" so filed them down a bit.
Use some plastic film and finger to spread the thermal goo around nice and thin.
Clamped. 2 small pieces of cardboard were a good fit to keep LED centered.
Fail, Part 1. Or should be Part A!
The Arctic Silver I received yesterday from Cutter was not quite up to the job.
After a length of time I should not admit to, I realized this 5 minute epoxy was not hardening.
It was checking the "5 minute" detail when I clicked.
Great customer service from Cutter, I emailed late last night and Elaine has already responded advising she'll resend.
Fail part 2: after cleaning my thermal "paste"off and using some older Arctic Silver 2 Part I had a satisfactorily centered LED
attached to the sink. Trying a few optics I overcooked it using my variable power supply.
Stupid late night mistake, in hindsight I won't use that power supply again (without a resistor in series) on smaller LEDs.
No biggy, I've already removed LED star and cleaned sink ready for new build.
Drilled the star.
