QUESTION: Concerning AA batteries at 3.7 volts Lithium versus 1.5 volt Alkaline Batteries and Light Output?
Took delivery on my DQG AA XP-G2 "R5 3B NW" today.
http://www.fancyflashlights.com/goods.php?id=424
This is my first AA LED that can handle "14500 lithium bats". I was hoping to see higher output using a 3.7 volt battery versus a 1.5 volt battery, but maybe it's my misunderstanding how some of these LED lights actually work depending on the electronics in the head unit.
In anticipation, I decided to stick with the well known brand "AW", and bought 2 "AW IR P14500P - Protected AA - 750 mAh" black labeled batteries, that charge fine on my Pila charger.
This particular light is listed as "Current Regulation", so far testing with a photo light meter (all I have to test lumen output), I am noticing very little actual increased output, from the 3.7 volt lithiums, to a standard 1.5 volt energizer or new, stock "Energizer Ultimate Lithium" which usually start off at 1.7 volts. My Eneloop 1.2 Volt AA's, do show a bit less light output. My simple light meter tests, show approx. ONLY a 1/3 exposure increase from the 3.7 v. lithium from the 1.5 v. AA alkaline.
The LED head does get VERY HOT with the 3.7 volt battery on high for more then a few minutes. Just using my hand for heat measurements, it does get hot with a 1.5 volt alkaline, but not as fast, but perhaps just as hot in while running (hot in this case is feeling almost too much heat to continue holding on, when squeezing the LED head with two fingers). This is not my major concern, light output was the goal, but if there is little difference in that aspect, not sure what the advantage is for using 3.7 volt Lithiums is now, unless one can simply get longer run times over a AA Lithium Energizer and of course the ability to recharge them?
Wondering if this is "normal" behavior, and if so, does this mean the lights "current regulation", steps down the voltage? I have read many times here that putting in 3.7 volt AA lithiums really increases the lumens output in most lights that can handle them, but that is based on comments on many various AA LED light brand topics here, and may not be related to the design of this light.
Confused?
Confused?
