I've got one of these chargers and 8 AA an 4 AAA cells in January. Here you pay 59? for the charger with 4 AA cells (that is about $75, the price you have to pay to live in old Europe .-)
It is branded 'Varta' here, a company not famous for good rechargeables.
And the 12V power cord comes 2 months later when you sent in a questionaire (and getting even more spam).
Varta told me, that their wall wart only works on 230V and not in between 100-250V like the US version (but I don't believe them).
Unfortunately US vendors seem not to be allowed to ship them abroad.
Anyway, the technical part:
I have tested the cells when they came, they ranged in between 1850 and 1900 mAh after the third charge (at 0.8-1.2A). A very good value, only about 5-7% below the statd value. All my other cells (1800-2200 mAh) are usually less than 7% below their rated capacity. Usually, the higher, the wronger.
But in pratical life, the ability for fast charging counts much, much more than a little bit more (nominal?) capacity.
As the cell 'monitors' it's internal pressure, this is much safer than any external detection of the charge state (voltage, voltage change over time, surface temperature). This also acts as an overtemperature protection. And against fast charge on cold cells.
Actually many people (including myself) have waited for a charging system which monitors cell pressure for decades. There are lots of fast and very fast chargers, but almost all of them work on assumptions about the cell's behaviour which are only true for maybe 95% of all cases. In the rest, the cells get overcharged with a high current. When your overtemp shut off is triggered, your cells are already damaged a little bit. And they collect their scars.
If the IC3 system works as expected (and everything now looks like it does), the cells should have a long life.
My only complaints are, that there are only two LEDs, not each for each cell (as over people have stated already).
The charger detects the IC3 cells by their conductive ring at the bottom, so if you insert just one of two cells not careful enough, it may not get the full charging current (I have to check that, I have the suspicion that cells get the same current).
I will check the cells after 30 or 50 cycles and post the results here.
One funny thing: When I got the cells I put them into my smart chrger to check their capacity and selected the program which cycles several times. But it did not work. Some cells showed 'error', and some a very low charging capacity (14mAh or something like that).
A moment later I realized what I made wrong: When the cells are charged, they shut off when they are full and confused the smart charger. So I only use the smart charger for discharging them (to get the capacity reading).
As the IC3 charger only needs 15 maximum, the fan noise is no issue. Actually, it is a feature, because when it stops, the last cell is full.
Last month I used the charger and cells on an expedition with very unrelyable power. The generator gives in between 150 and 250V (actually 390V maximum) and the charger did not care about the voltage change. I think it is the same device as sold in the US, just with the European plug.
Several expedition members will buy IC3 cells and chargers when we can find a source in the US which ships to Europe.
I will throw out my other AA and AAA cells ASAP.
