D
**DONOTDELETE**
Guest
I need help. I'm confused. I want a "flashlights-for-dummies" explanation of the relationships between battery voltage, lamp ratings, rechargeable vs not. Consider the following example, which focuses on my Petzl Zoom headlamp.
My Petzl Zoom takes 3 AA-cells, which means 3 * 1.5 = 4.5 volts.
However, I want to use rechargeables, so I stick in Ni-MH 3 * 1.2 volts = 3.6 volts. This results in low brightness and shortened life. My questions are these:
Is the diminished brightness a result of the lower battery voltage? What if I put in a lower rated bulb? Will it be brighter?
If so, what if I put in a bulb rated for the 2 AA-cell Petzl Micro (i.e. 2 * 1.5 = 3.0 volts)? Is 3.6 too much voltage for a 3.0 bulb?
Is the lower life a function of 1. incorrect configuration in respect of bulbs/battery voltages or 2. a fact of life with rechargeables?
Do I need to consider mAh's in any of this?
I'm going to probably get a 4 D-cell Maglite and go through the same exercises. Any help is appreciated.
