Malkoff
Page 6 of 33 FirstFirst 1234567891011121316 ... LastLast
Results 151 to 180 of 969
Thread: MBI #4 - Get Ready to meet Zeus™
  1. #151
    Flashaholic* DBCstm's Avatar
    May 2009
    Heart of Texas
    Default Re: MBI #4 - Get Ready to meet Zeus™
    I must be getting old. As much as I'd love to see it in Ti, the efficiency increase of Al is more appealing at this point. Can I reserve the right to change my mind?
  2. #152
    Flashaholic* KDM's Avatar
    May 2012
    Tennessee
    I put in for a SS version. Love the weight of Al though.
  3. #153
    *Flashaholic* HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by KDM View Post
    I think it is a problem when he makes it in a couple of different metals. I have a very hard time deciding which one, you can see what happened with the last lights from him:
    And now I will probably add a couple of Zeus to that collection and also some Torpedoes.
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
  4. #154
    May 2012
    Tennessee
    Very nice collection you have there HKJ! Ti would be my first option but it wasn't a listed option yet.
  5. #155
    Is the 2nd light from the left made of Bass? How do you keep track of the battery capacity so it doesn't over discharge? Does the light have Over discharge protection?
  6. #156
    *Flashaholic*
    Jan 2012
    NJ
    Buttrock Re: MBI #4 - Get Ready to meet Zeus™
    These are pocket rockets...you (As in YOU) keep charge of the cell's charge by simply noting that the light's getting dimmer.
    If its getting dimmer, its drawn down and you can throw in a freshie. You then use a DMM to measure the actual voltages to see how far down that was...and adjust your use accordingly.
    If you leave the light on, it will suck the cell drier than a dingo donga.
  7. #157
    May 2009
    Heart of Texas
    Provided you're smart enough to use a DMM in the first place. I just attempted to measure voltage on a Samsung INR18650 20R while the DMM was set to Amperage. In about 3/100's of a second I burned 2 fingers and threw the cell on the floor! My 6 yr old was be-bopping all over the place asking a zillion questions and I got distracted. Duh! Bet I don't do THAT again! 20A hurts like ....well it's like spot-welding your finger tip.
    Was pulling 5.18A through an XM-L2 T6 by the way.
    Dale
  8. #158
    *Flashaholic*
    Jan 2012
    NJ
    Good thing it burned you, because if the current went THROUGH you you might have been toast....fibbed out, etc.
    People have died from a few ma if its routed bad.
  9. #159
    May 2009
    Heart of Texas
    I have large 12ga leads for checking amperage. I was pressing the tip of that lead onto the battery, spark bite toss. Finger still hurts! lol Yeah, lucky me, that's all I need is to get caught dead making a stupid mistake. :P
  10. #160
    Thanks for all the posts and fassst signups to the list,
    and appreciate all the feedback too, some of which was as below
    Titanium
    Definitely planning to make Titanium Zeus,
    its mostly a limit of how many things I can produce simultaneously which determines timing.
    Copper, same as Ti
    Switch
    The Zeus switch is custom meaning its not like a standard P6 style switch-kit, rather its the raw smd/component switch, mounted on a custom PCB board/pad, with everything else completely custom too.
    We are currently reviewing the final smd switch choice to ensure the amperage rating is high enough to handle just about anything (upgrades). The switch is fairly easy to swap out though. (from memory) Requires unscrewing of one ring in the base of the tail and everything else is easily removed in case you ever need/want to upgrade/change it.
    With all the designs I've delivered to date, the switch mechanism has often been the most difficult part to stabilize and implement due to size limitations and that in turn has resulted in hundreds upon hundreds of hours of inspection,testing and redesign, just on switches.
    For Zeus, the switch design has to be simple to operate, 100% reliable in any circumstance, and also very easy to swap out.
    I believe its all of the above and more.
    Tgwnn
  11. #161
    Flashaholic* emu124's Avatar
    Aug 2010
    Switzerland / CONUS address
    Subscribed!
    Actually I'm waiting for a Ti 3-mode (with a low around 3 lm), but most probably I'm not that patient and buy a Zeus from the first run
  12. #162
    Flashaholic cactux's Avatar
    Nov 2012
    Australia
    @Guy regarding the clicky switch and the waterproof features.
    * Are we going to be able to play with the switch (on/off l/h) underwater without damage the switch or flashlight?.
    * Since this guy is going to be used under a whole new diferent environment (underwater) how are you considering to stay away from wrong usage recalls, like people using this flaslight to go beyond +10m?.
    * Is it possible to use any kind of AA battery at that depth (10m)?
    * What is the expected life of the clicky switch?.
    Guy what about creating a post with all the FAQs in that way you can direct the guys there if they want to read the whole subject, instead of answering multiple time the same question. That may save you some time ;-)
  13. #163
    Flashaholic* windstrings's Avatar
    Feb 2005
    N Central Texas
    Quote Originally Posted by TEEJ View Post
    I never knew their dongas were that dry?
    _____________________________________
    Alan
    Prev- Xeray BB 75W HID, Acro 990X, JET-I PRO, M1X LED,Oracle 35W HID , P1D Q5, L35-35 watt HID, Zebralight H30, H31W. & H60W LED, Quark MiNi 123, Quark MiNi 123 TI, Fenix PD 10 ti, DEFT LED-35/80W HID Mule, OLIGHT-SR90-2200L LED, 1.9watt blue laser, FFIII HID, Nitecore TM26
  14. #164
    Quote Originally Posted by emu124 View Post
    Subscribed!
    Thanks so much emu124
    Quote Originally Posted by cactux View Post
    Hi Cactux,
    Thanks very much for the questions and the FAQ thing is such a great suggestion!
    Hopefully, I can keep it current but I'll plan to add an FAQ at the bottom of the first post and edit/update it as needed.
    Everybody, feel free to make suggestions on what to add or edit as needed.
    Q. Are we going to be able to play with the switch (on/off l/h) underwater without damage the switch or flashlight?.
    A. Yes, that is the plan. We'll need to test of course but the design goal is to allow you to use it Zeus underwater.
    Q.Since this guy is going to be used under a whole new different environment (underwater) how are you considering to stay away from wrong usage recalls, like people using this flashlight to go beyond +10m?.
    A. Wrong usage, the way I understand it is not a reason for recall if the usage instructions/limitations are made clear.
    I plan to make the limitations clear in the manual and package.
    Hoping I understood your question correctly but if not, please feel welcome to correct me as needed.
    Q.Is it possible to use any kind of AA battery at that depth (10m)?
    A.Yes. Just like being in a submarine that is pressurised.
    Q.What is the expected life of the clicky switch?.
    A. It will depend on the final choice but typically between 10,000 clicks as the absolute low end to 100,000 as a high end number.
    Tgwnn
  15. #165
    *Flashaholic*
    Jan 2012
    NJ
    Quote Originally Posted by windstrings View Post
    Alan
    Do you spend a lot of time pondering things like that? I'm not even sure what the units of measurement are for Donga Moisture Measurements.
    If you use a DMM (Donga Moisture Meter) just be carefuil to not burn yourself!
  16. #166
    May 2009
    Heart of Texas
    You mean the DMM isn't for batteries?!? So THAT's what I was doing wrong! Where's a Donga, I've got something for his ornery a self!
    Um, what's a Donga?
    Never mind....reconfiguring my DMM to believe Li-ion cells are Dingo's.
  17. #167
    May 2009
    Heart of Texas
    CATARACT! See if Uni can catch the dingo! He's got DMM leads hanging from his ...well you'll know him when you see him!
    Pesky varmints!
  18. #168
    *Flashaholic*
    Jan 2012
    NJ
    Quote Originally Posted by DBCstm View Post
    Pesky varmints!
    Those aren't leads, that's his....well, you'll know when you see him...
  19. #169
    *Flashaholic* gunga's Avatar
    Nov 2006
    Vancouver, BC, Canada
    Default MBI #4 - Get Ready to meet Zeus™
    Hmmm. Is this a mechanical switch (clicky) or an electronic switch?
    I'd love 3-4 levels and titanium too
  20. #170
    Feb 2005
    N Central Texas
    Um, what's a Donga?
    Now see you there? You caught my mind in the gutter again!
    When I'm tired my thoughts are like static electricity they go all over the place no real circuit board the follow!
    Alan
  21. #171
    Feb 2005
    N Central Texas
    . :thumbup:
  22. #172
    Quote Originally Posted by gunga View Post
    The spec on the first page says clicky. I hope he sell spares.
  23. #173
    Nov 2006
    Oh thanks, missed that. I put my name on the list. Really looking forward to this...
    Funny, I wasn't before. Now I WANT ONE!
  24. #174
    May 2009
    Heart of Texas
    Guy also states that testing is being done to ensure the switch is capable of handling the amperage of future upgrades meaning that it's fully capable of handling the current as it's set up and he's even going to lengths to ensure it will still be capable when he get's new heads, drivers, emitters in the future.
  25. #175
    Quote Originally Posted by the_guy_with_no_name View Post
    Hi HaileStorm,
    Good questions, thanks.
    Trit colors > sure, these will be an optional pre-install choice so you can choose the colors.
    I'll have to check but as a minimum: green, blue, red, yellow, purple, etc...
    Output > still not released.
    Zeus has 2 voltage ranges depending on the battery type used
    1.5V AA (eg. Alkaline/NimH/etc)
    3.7V 14500 (li-ion AA)
    Power on 1.5V group will be lower
    Power on 3.7V group will be higher
    Pending some final testing but roughly 250lm with the 1.5V group on high mode (maybe more/maybe less).
    I'm tempted to push it a little higher, eg 300lm but may save that for V2 because I don't think the difference is worth the runtime impact (without additional modes to a AA only user) and of course the 3.7V group will provide you with many more lumens if you want it.
    Its funny but I was outside a couple of nights ago, and switched on one of the proto's running a AA and it was surprisingly more than adequate. The power of focus!
    Tgwnn
    Thanks, tgwnn! This sounds like an outstanding light! Very, very tempting as I've never owned a 14500 and a custom light. This might just be my first. :thumbup:
  26. #176
    Do we have an expected ballpark price yet?
    Sent from my SCH-S720C using Tapatalk 2
  27. #177
    Quote Originally Posted by lightcycle1 View Post
    This from Guy's post #33 in this thread...
    "No firm idea of price yet as that's always the last thing in my mind when I design something.
    I just like to aim for best, and then let the rest work itself out.
    I'm still waiting on final costs for the circuity, etc..
    but a very rough guess for AL/SS would be $130-$160 (+optional trits pre-installed).
    There are still a few things to work out on the cost side and some things not yet factored in and of course depends on the final "what's in the box" and what could be an "option" but as long as everything falls into place the way I'm planning it,
    Zeus™, could well be the last AA flashlight you ever need/buy."
  28. #178
    Good enough thanks. I didnt read closely the whole thread. Sounds reasonable.
  29. #179
    Reserved a slot for a Zeus and subscribed. :thumbup:
  30. #180
    I know, it's easy to miss posts when the thread is active, and if you aren't reading almost daily then you're sure to miss stuff. I happened to remember that Guy posted something about pricing and since this thread is still young and therefore short, it was easy for me to find it.
