stoli67
Not sure if this is helpful but it has all the info that I look at!
I have it all on one sheet and keep a copy at home, work and on my phone.
It usually prints out straighter than below I had to put the underscores in as the tabs kept getting removed.
HDS ____________________________________________SPY007
Option Menu: _________________________________________• PU1 is to select the configuration. (1 of 4)
<long flash> Turn On Preset ______________________________ • PU2 is the lock; same as in the 007
<three rapid flashes> Button Lock (BL) ______________________• PU3 is the calibrate; same as in the 007
<bright-to-dim-ramp> Automatic Turn Off ___________________ • PU4 is the light engine programming
<dim flash> Locator Flash ________________________________ • PU5 is the power level report
<long flash, short flash> Momentary (M) _____________________• PU6 is the battery meter; same as in the 007
<brighter-dimmer> Burst
<dim-to-bright-ramp> Disable customization (Cust)
Reset, 20-click, PHR Enable customization (Cust)
LF2XT ___________________________________________________ LF3XT
3C Temporary disable Auto Off
3C + PH To setting mode ____________________________________Setting mode entry
4C Toggle Tactical __________________________________________Toggle Tactical
4C + PH Toggle ODP ________________________________________Function setting mode entry
5C Battery Voltage Report ____________________________________Battery Voltage Report
5C + PH To FUI ____________________________________________To FUI
6C + PH To mode Number select
7C + PH Toggle Memory
8C + PH Toggle Auto Off
10C + PH Restore Factory Settings
BATTERY CHARGING
BATTERY CHARGING
Cell | Size | Max charge rate | LiIon Battery Charge Status | ||
10440 | AAA | 0.3 A | 4.2V | 100% | |
RCR 123 AW | 123 | 0.7A | 4.1V | 87% | |
1640 IMR | 123 | 1.5A | 4.0V | 75% | |
14500 | AA | 1.5 A | 3.9V | 55% | |
18490 AW | 2.5A | 3.8V | 30% | ||
18500 IMR | 4.5A | 3.5V | 0% | ||
18650 | 4.5A | ||||
26650 | 5A |
