Capolini
Banned
I think this is common with most if not all Flashlight manufacturers.I will get to "This" in a moment
I have Two Fenix Flashlights and was thinking of getting a third. I have the TK-75 and the TK-35. I like both of them a lot. A minor issue with the TK-75 that is now resolved and the TK-35 has had no issues!
So, I was thinking of getting a Third Fenix light, the PD-35.A very popular light that people seem to like a lot. What I noticed after downloading the manual[Three websites do NOT mention this] is that Turbo will work 5 minutes and then step down, They warn you if you continue to step back up that it can harm the light and lessen its life.Ok,,,I understand, not everyone is a turbo freak like me!:twothumbs
Here is where I have the problem!! They ADVERTISE that you can get 1 hour and 15 minutes of turbo??!! That is very misleading. Advertising ploy? I think so! Why do they do that? You certainly can not run it that long on turbo.:thinking:
I also have the new version of the Nitecore EA4. Same story! They advertise 1 hour 45 min. of turbo, yet it steps down after 3 minutes and they also[I emailed main HQ] told me you can step back up, however it may generate too much heat and damage the light if you do it too many times.
A mistake I made was I found out after the fact!! I ordered the EA4 then looked at the "User Manual"!! That was my fault! I still like the light even though I am disappointed in the misleading run times they advertise.
I want to make this CLEAR! I like my Fenix lights and also like the Nitecore EA4 that I have. In no way am I condemning either of the Two manufacturers. I would certainly consider buying lights from either company again. The turbo specs. just have to be as advertised!!:thumbsup:
Your thoughts and experiences would be appreciated!:thanks:
EDIT: I would be remiss if I did not include this!
The TK-35[U2] that I have states that it gets 1h 37min of turbo using the CR123A batteries.It steps down after 25 minutes but you can step up again with no heat issue and warnings by manufacturer!
I got 2h 6min. of turbo using my genuine 18650 Panasonic 3400 Mah cells!!:thumbsup::twothumbs
