Malkoff
Page 19 of 21 FirstFirst ... 912131415161718192021 LastLast
Results 541 to 570 of 616
Thread: AquaMule and AquaRam 18650 lights ** Terra versions added**
  1. #541
    Default Re: AquaMule and AquaRam 18650 lights ** Terra versions added**
    Quote Originally Posted by the badger View Post
    I’ve got a few questions regarding the Aqua Ram.. and unfortunately I either missed the answers here or they haven’t been fully discussed yet:
    - What is the runtime on the XPG2 Ram?
    - Not that it matters cause I’ll be buying one regardless, but what is the output on the XPG2 (and is it max driven at 1400mA)?
    - How do I get one of those lanyards on that girl’s waist in the above pics?
    Any info helps
    There are more experienced people here that can answer these questions better than I but the Aqua Ram has a programable head that can be set up to be a max of 2200mA I believe and has many settings in between and can be programmed to about 21 or 22 setting I believe in 100mA increments with up to 5 settings per mode across three modes....you need to go back to OP and see driver post link for info.
    Go to McGizmo's Sub forum and there is a Lanyard thread.
    Trip
  2. #542
    Oct 2012
    Gilroy , Ca.
    Forget about the lanyard ......how would a man my age get one of those girls .....LOL
  3. #543
    Feb 2013
    Vancouver BC
    Thanks for the reply Trip. I am aware of the custom programming but I also know that Don runs these lights lower than what they can handle as a way of increasing efficiency. I’m intending on leaving it the way Don ships it. I have plenty of modded lights that are way brighter…but that is not what I’m buying this light for
    Quote Originally Posted by djdawg View Post
    Thailand
  4. #544
    Feb 2013
    Vancouver BC
    Quote Originally Posted by Trip Miller View Post
    Hmm I'm not seeing it there?
  5. #545
    http://www.candlepowerforums.com/vb/...eel-connectors
    So if you are not going to change the setting on the max as delivered then I believe you are correct that it is 1400mA stock.
  6. #546
    Feb 2013
    Vancouver BC
    Thank you trip
  7. #547
    Feb 2013
    Vancouver BC
    Don, order placed for an AquaRam with XPG2.
    *Edit* Please include the orange o-rings
  8. #548
    Welcome. Nice!
  9. #549
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    .... what is the output on the XPG2 (and is it max driven at 1400mA)? ....
    I believe the XP-G2 emitter is rated for a maximum current of 1500 mA. As is standard for McGizmo, it is driven conservatively with the stock maximum set to 1400 mA.
    Although the programmable driver may allow overdriving this LED, it is unlikely to provide much of an apparent increase in brightness ... but at the expense of decreased runtime, increased heat, and shortened lifespan and/or possible damage to the LED.
    ... is the archimedes peak
  10. #550
    Feb 2013
    Vancouver BC
    archimedes, thanks for the info! However I'm still curious how the XPG2 output compares to the XML2
  11. #551
    Quote Originally Posted by archimedes View Post
    Great point on the XP-G2 max....
    the badger..just google cree XM L2 and XP G2 and look at data sheets and all of it is there. It is not too hard to follow and i believe those sheets show flux outputs by BIN...
  12. #552
    Mar 2013
    Boston
    Quote Originally Posted by dinokay View Post
    Loving (a lot) the latest additions to the family, Thank You Don.
    Can i ask which McGizmo is the largest one on the left? I'm wondering which McGizmo would be the best candidate to mod for lots of power, that head has tons of room for copper heat sink!! (or is there even a bigger McGizmo?) Thanks
  13. #553
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Quote Originally Posted by BeastFlashlight View Post
    Can i ask which McGizmo is the largest one on the left?....
    That's the Makai
    ....(or is there even a bigger McGizmo?)....
    Yep, the HD45
  14. #554
    Mar 2013
    Boston
    Oh great thanks a lot! I actually didn't know that he made non-titanium lights, so Makai is his largest titanium light and HD45 is his largest light. He says HD45 is incredibly durable so purhaps not totally ruled out (although not titanium)
  15. #555
    Flashaholic* tino_ale's Avatar
    Nov 2005
    Paris, France
    Anyone would be kind enough to compare beam profiles of the XM-L vs. XP-G2 versions ?
    Bead Blasting McGizmos - PM disabled, email aoc.paypal (at) gmail.com
  16. #556
    *Flashaholic* PoliceScannerMan's Avatar
    Jul 2005
    Gainesville,FL
    Quote Originally Posted by tino_ale View Post
    It is what you would expect, I once owned both. XML is cooler with a fuller, floodier beam, still plenty of throw. XPG is throwier, tighter and not as floody and warmer. XML has sheer brightness when cranked to 2200mA, so the brightness more than likely makes up for the bigger die and ultimately ties the XPG in throw. Just guessing. If I had to pick one I would go XML. Tint is pure white, not cool yet not warm. White.
    In no order: HDS/Malkoff/OVEREADY/McGizmo/Sky Lumen -PSM
  17. #557
    Nov 2005
    Paris, France
    Thanks PSM
  18. #558
    Do these battery packs interchange with all the other lights?
  19. #559
    Quote Originally Posted by jso902 View Post
    No. These are a completely different size than the E series type threads that are on the other current production McGizmos.
  20. #560
    Mar 2013
    Boston
    Quote Originally Posted by PoliceScannerMan View Post
    Just curious for those who scuba dive, is throw by far prefered under water? XPG2 over XML2? I'd imagine it is
  21. #561
    FYI tapping the tail of the light is great, but it can bend the the little metal part on your aw protected cathodes.
  22. #562
    Jul 2005
    Gainesville,FL
    I would think underwater the XML would be the choice. XPG may give a tunnel vision effect where the fuller beam of the XML lights the path. XML still throws a plenty.
  23. #563
    Got this last night. 119v aqua ram. Awesome feel to this light. Very nice CRI and tint.
    Kevin
  24. #564
    I don't think this is particularly the case as it depends on a few different factors. For example, sometimes I dive in low visibility conditions where there is a lot of debris in the water and in this case the more floody beam would cause a white wash infront of me and hinder my vision rather than aid it so a tighter beam would be better. In great vis conditions flood would be good as would a tighter beam so either would be fine.
    I generally don't use a light when diving as I don't often dive too late into the evening or do alot of scuba, mainly free diving, so usually about 20m covers it but I do spend alot of time in the water and occasionally use lights doing so.
    Given the choice I'd take the XPG or 119V over the XML in a Ram and if I could extend on that I'd take a Mule too and have the best of both options.
  25. #565
    Kevin,
    Nice pics. If I ever get another McGizmo I think I'd go for that very light and emitter combination.
  26. #566
    Jul 2005
    Gainesville,FL
    Quote Originally Posted by F89 View Post
    Good points, I didn't consider murky water, I pictured the crystal clear water in Hawaii.
  27. #567
    Ha Ha exactly. Don's photos definitely depict just about perfect conditions.
  28. #568
    Thanks! I have an xml2 head now too. The nichia really is bliss. Zero eye strain it's just very natural light.
    I've been carrying the xml2 head recently. Much better reach out in the fields and I have a flood high cri peak copper eiger on my keys. Really nice. Not as nice as the nichia, but still pleasant.
    Kevin,
  29. #569
    Quote Originally Posted by richstag View Post
    I've got to stop looking at this forum.
    After throwing around more than sane amounts of money I'm keen for an AquaRam and AquaMule now in 119V or XPG2.
  30. #570
    Unenlightened debragail's Avatar
    Feb 2015
    Port Macquarie, NSW, Australia
    Question Re: AquaMule and AquaRam 18650 lights ** Terra versions added**
    That's the exact decision I'm trying to make.
    I've owned my Mule for 5 days now and I just love the beam. I thought "this will be the last torch I ever buy, the fleet is complete."
    Then I read this forum!
    I've emailed Don and and asked for his opinion.
    Decisions, decisions.
