Why are you asking this? What is it you want to do?
Yes, look for trashed headlights that use those LEDs. They will have optics designed for those LEDs. They will also only project a headlight pattern. If you are asking if you can take a linear array and make a nice, throwy flashlight, then no, doubt you'll find anything. Best you could do, I'd think, is to find a light that uses a filament the size of the 1x4 array. Probably be looking at ~50W halogens. Then, you could try your hand at finding a way to mount the LED so that it is positioned where the filament was.
If LEDs with no optics still isn't diffuse enough, you could put them in a white box with a diffuse front to make the light a bit softer (and dimmer, can't have your cake and eat it too)
