AnthonyMcEwen2014
I'm looking at getting a fenix as an EDC to replace my P14 which is to big / heavy / not bright enuf.
I'm likely going to end up with a PD35 as have read the whole of this thread http://www.candlepowerforums.com/vb/showthread.php?361481-pd35 and despite some negatives like tint ( that doesn't bother me) it looks to me to be what I am after. Shame about no tailstand through, not bothered by the spikes at the the end of the the light whatever they were called, SOS is a shame but not a deal breaker.
Also looking at the TK22 SE but its not quite the same shape as doesn't look like it would be as good as a EDC to slip into a pocket ect....anyways what I get is not the question here
WHAT I WANT TO KNOW IS how dose fenix manage the step down, let's take the PD35 it steps down from 850-450 after five mins but that's not an issue but it steps down yet again from 450 after 30mins, this is due to heat, however dose it step down on a timer or dose it have an actual heat senser then step down when it hits a certain temp.
As I planned on also using it as a helmet mounted bik light or even bar mounted so I hope its NOT a timer as on a bike it would have cooling so I was hoping I could run it on the 450 setting indeffintly or at least a lot longer than the half hour stated by fenix as 450 is OK for my type of ridding but if it steps down on a timer after 30 mins it would drop down to 170 which just would not be enuf, and really a shame, I really do hope they do it on actual heat sensor over a timer as it means with the extra cooling I could run the high mode much longer as the heat would not build up so fast and trigger the step down and i could use it as a viable alerntive to expensive bike light.
Really sorry for the long winded question but I really appreciate your help thanks!
