I received the unit in a timely manner and it seemed to function fine. Im noticing that both the head and tail cap need to be in the "right" position for the light to function properly (with any battery set i have tried). If not, it may start on strobe and i have to mess with the head position a bit. It does not suffer from the inability to hit high or "turbo" mode like tha last unit did. To be quite honest, this light functions properly about 50% of the time i pull it out. I can always get it to work but it has been an over-all negative experience for me and not what i expect out of a light at this price point. I have not notified 4Sevens of this and have no plan to as i dont want to RMA a second light. It works.... kinda... when it works.
Any questions, feel free to ask. Have a great holday guys....
Functioning ~50% properly sounds like the clicky retaining disk may be loose (tighten with needle nose pliers), or the screw down collar over the clip may be loose, which will prevent the tailcap from seating fully. The tailcap should only be tight, not sure what you mean "in the right position." Agree the head needs to be in the right position though - either tight, or ~1/3+ unscrewed, otherwise sideways pressure to the head can activate tight bezel max. Truth be told, though, this one of my all time favorite pseudo-features of any UI - If you are ~ 1/10th turn away from the tight bezel position, any sideways pressure to head gives you momentary maximum for as long as you apply pressure, and the light returns to the previously used low mode when you release. Favorite off-leash dog walking UI, single-handedly and without having to change modes, I can quickly spot my dog, investigate that bump in the woods, or fire a couple millisecond flashes at approach vehicles to warn them pedestrians are ahead, and/or to lower their high beams.
If a loose clicky retaining plate/clip collar do not fix your issues, then absolutely RMA (whatever it takes) and make 47s make it good. It's what they are there for, and what you paid for.
PS, you can also test if the issue is in the tailcap or the head by by-passing with piece of tinfoil... just remove the clicky and touch both the neg battery terminal and bare edge of the battery tube.
