Fenix Outfitters
Results 1 to 5 of 5
Thread: Help with Nitecore EA4
    Default Help with Nitecore EA4
    Hi guys,
    I'm pretty new on this website and the whole world of fancy torches. I have what I hope is a simple query in regards to the Nitecore EA4, in that when I use it, even for a few minutes the the handle/outside battery compartment area, starts to become warm, when used in the higher modes. I am using Eneloop batteries.
    Is this a common trait in these torches? Any advice would be appreciated.
    Thanks
    Oct 2013
    Prescott Aridzona
    Default Re: Help with Nitecore EA4
    I received my new EA4 just today.
    It is sitting on the table next to me, in turbo mode. Yes, it is getting warm. Heat from all that light output has to go somewhere!
    This light, like most others, has "fins" around the head, like an air cooled motorcycle, to aid in dissipating the heat.
    schizeckinosy's Avatar
    Jul 2008
    Gainesville, Florida
    Getting hot is good - you want that because it means that the heat from the LED is going somewhere. If it stayed inside it will kill the LED quickly. If you hold it in your hand the heat will go into you and keep the torch even cooler! So, yes, this is normal.
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    Ditto, completely normal.
    Flashaholic* mcnair55's Avatar
    Oct 2009
    North Wales UK
    And some of the little ones get hot, one of my Fenix products even has a warning on the head.
    Diagnosed with Grumpy Old Man Syndrome
