Fantastic light with built in charger, performance upgrades including xm-l2 swap and current boost. Just too large for me to use often. As new, includes everything in photo. Note:holster is not shown in photo, but will be included. $160 tyd cont. USA or canada. These lights are currently unavailable as both batches with mods sold out. THE ONLY DIFFERENCE BETWEEN THIS LIGHT AND THE V54 THREAD IS THIS LIGHT IS NOT DEDOMED. It can be done at anytime if that is your preference. This light is more floody and has more lumens than dedomed. If you haven't seen some of his other modded lights available, check out the fantastic work he does. Comes with everything shown, case, car/home charger, instructions, warranty card, spare o-rings etc.
also listed on cpfmarketplace
Link to vinhn page with mods and beam shots :
http://www.candlepowerforums.com/vb/showthread.php?370540-WTS-X40vn
Selfbuilt review of stock light here:http://www.candlepowerforums.com/vb/...EAMSHOTS-VIDEO
Supbeam link (stock):
http://www.supbeam.com/en/supbeam-led-flashlight-x40#.UnUZobK9KSP
Modification Details:
- Current boost from 2.5A per LED to 3.1A per LED. Batteries are in Parallel.
- 3450 LED Lumen
- Larger wires
- Tail cap clicky tweaks
- Easy current flow tweaks
- Better thermal compound for improved heat dissipation.
- Battery carrier tweaks
- All UI work as factory
- Overall this modded light should be more reliable and efficient than factory
- XM-L2
- 3450 LED Lumen
- Larger wires
- XM-L2
