HIDSGT
this light in absolute JUNK! do NOT buy this light. its flimsy, rattles and poorly made. the magnetic charging system is an absolute JOKE! the magnet does NOT stay on the charging port. it has virtually zero magnetic force to hold it. if you just touch the wire to the magnetic charging port it just falls right off. same thing for the car charger magnet which makes it absolutely worthless to take in the car with me to charge it. I had to place a piece of tape over it to keep it from falling off. junk!
the on/off switch at the rear of the light just doesn't work worth a chit cause the light is top heavy and therefore really awkward and unbalanced to hold and turn on/off. the switch needs to be up front like Olight has it. the light is similar to the RC40 but much lighter.
I have been charging it for two days now and the charge light is still showing RED. its just cheap poorly made China crap is what it is. the light is bright no doubt and throws further then the SR96 simply because it has less spill and more of a hotspot. batteries rattle around inside it.
NOT impressed at all. ill stick with Olight for now on.
