Re: Are Regulated LED Flashlights Always Preferable Over Non-Regulated LED Flashl...
People say current regulated lights have more tint shift at low lumens, and that PWM lights maintain more even tints, but I don't see any difference (
HERE is a pix of sub-lumen and ~100 lms, and one light is PWM).
Give me current regulated any day.
It's a pretty slight tint shift above 1% rated drive current, but it is there. You'd need a constant-current flashlight with moonlight, and a PWM-capable flashlight with equally dim settings, to see it.
But "What is regulation?" In some ways, PWM is a form of regulation. Constant current is supplied (100% drive level) and flicked on/off to create different duty cycles of constant current and off.
"Regulation" can mean closed-loop feedback (A device measures the actual current or even lumen output and adjusts parameters to reach a set level).
Regulated can also mean open-loop control (Run so that the sense resistor sees xx volts).
Regulated can be open-loop with a gain factor (PWM).
Heck, I could say that my resistor 'regulates' about 0.4v off the 3xAA pack so the LED doesn't burn out. What is regulation?
If we just go with the output: Is "Regulated" ruler-flat output until the battery is dead, then total darkness? That's great for some people. It's life-threatening for others. I have some lights that do this. It's frightening when they go flat without a warning signal aside from keeping a stopwatch running to count battery life.
Other lights of mine tail off output from the moment I turn them on. Sometimes just what I want is 5 hours of light that keeps going, even as it gets dimmer. That would certainly be 'unregulated...' Unless I programmed the controller (Or response to battery discharge) to regulate that pattern. Regulation is tricky, since it has many meanings. In other words, I can regulate a light by several mechanisms, to create several regulation profiles, with several regulation patterns. As with
all things, the most important thing is that a product fills your needs, than that it has the coolest super-regulated or hyper-tapered output profile. Do you need constant video light or a lot of stretched runtime during a power outage? Purchase accordingly. Look at runtime charts (Made by CPF members) for more information about lights you're considering.
Mechanism: Drive circuit and input to driver.
Regulation profiles: Flat or tapered?
Regulation pattern: Constant-current, PWM, hybrid?
