Here are some photos of my modified Maglite 3D using a 8x7135 driver and HAII heatsink I had laying around. I used a Cree XM-L2 (Neutral T5) from Illumination Supply. I had to cut the MCPCB down from 16mm to about 10mm to fit on the heatsink. I did that with a dremel with grinding wheel. It was a pain to hold it and the LED ended up coming off, it wasn't soldered very well to the board. There was only two tiny spots of solder under the heat sink and one tiny spec on + and - pads, very poorly done. So, I had to re solder the LED to the MCPCB using solder paste and a heat gun. I am powering it with 3 10000mAh NiMh LSD batteries. Etching was done today on a 50W Epilog Laser with rotary attachment.
