Vinz
Hi, folks!
For sale are two MD26E Triple-219 Drop-ins. The drop-ins are hand made and designed to perfectly fit Solarforce hosts, like the L2, L2N, L2m, L2P or P1D, using unprotected or short protected cells (NCR18650PD recommended).
Some details:
SOLD: The Price for one drop-in is $100, plus $8 for registered international shipping with tracking. PayPal fees are included.
Same as above but with flash.
Some details:
- LEDs are soldered under slight pressure onto a copper MCPCB without dielectric (perfectly centered)
- Hand selected LEDs with perfectly matched Vf (+/- 0.002V)
- LED-MCPCBs is glued using a diamond thermal adhesive (80%+ diamond by weight)
- Carclo 10511 optic for a flawless beam
- Whole electronic potted by a diamond thermal adhesive
- Best PTFE sleeved silver plated oxygen free copper wires (22 AWG) - Soldered with best Mundorf Silber/Gold solder (contains silver and gold)
- Made of one piece of Aluminium
- Solid contact for low contact resistance
- Low-voltage and reverse polarity protection
If the light is off for more than 1sec. it will always start in a moon mode (1lm), but if you circle through the modes while it is running you'll get only into low-med-high. To get into the moon mode again, you have to switch off the light for more than one second.
The moon mode lasts for over 900 hours with a stable output over the whole runtime.
