I am hoping that Fireclaw18 will share how he took apart the Eye10 as I would like to get rid of most of the detents. I like detents only at strategic locations that correspond to 0, 50, 100 % of output.
Regards
Here's how to disassemble the Niteye EYE10:
1. Unscrew the stainless steel bezel. Mine came with no threadlocker on the bezel, but if you do find threadlocker, use a strap wrench or rubber jawed pliers. If you're like me and don't own either you can make simple rubber jawed pliers by cutting out strips of rubber indoor stairway grip tape and attaching it to the jaws of some regular pliers. Place one pliers on the bezel and the second pliers on the part of the head
ABOVE the ring and turn to unscrew and remove the bezel and lens.
2. With the bezel off, remove the reflector. It should fall right out.
3. Remove the plastic centering disk over the star, then desolder the leads to the star.
4. On the inside of the head, use a very small phillips screwdriver to unscrew the driver retaining screw. The type of screwdriver used for glasses repair works.
5. Remove the contact plate and the driver circuitboard from the head of the light. They should lift out once the retaining screw is removed.
6. Unscrew and remove the top section of the head. The remainder of the head consists of 3 sections: The top portion above the ring, the ring, and the bottom portion below the ring. the top and bottom portions screw into each other below the ring. They even have an o-ring for waterproofness. This join is threadlocked, so you're definitely going to need the rubber jawed pliers or strap wrench described in step 1.
7. You should now be able to lift the ring out. Be very careful not to lose the very tiny ball bearing and spring on the side of the ring that triggers the detentes.
Suggested modifications:
(a) Notice the row of holes in the side of one of the head sections next to the ring. The ball bearing goes into those holes triggering the detentes. If you want fewer detentes, use soap and water and clean out all the grease out of the detentes. Then fill in the detentes you don't want with some kind of hard glue or resin. Arctic Alumina might work, or maybe something stiffer and harder like Norland. I haven't tried this mod myself, but see no reason why it wouldn't work.
(b) Replace the stock aluminum star with a direct copper star (Noctigon, Sinkpad, or Illumination Supply brand), and your choice of emitter. I prefer 5,000k neutral tint XM-L2.
(c) Replace or augment the grease around the retaining ring. You can adjust the feel of the ring by using a different grease or adding a different grease underneath and around the sides of the ring when the light is disassembled.
WARNING: It is very important to follow the dis assembly steps described above in order. If you accidentally unscrew the top section of the head (above the ring) and the bottom section (below the ring) while the driver is in place you WILL DESTROY THE DRIVER!!! The twisting action will break the driver leads. Worse, the driver itself is sandwich of 2 boards with the leads soldered to the inside of one of them. It's virtually impossible to solder new leads on if you break the original ones.
These same instructions can also be used to disassemble the Jetbeam RRT-01 and TCR-01. They have the same internal setup.
