BentHeadTX
Hello All!
My 18 LED flasher is starting to get long in tooth after 4 years of use (longer than most of you guys use LEDs) /ubbthreads/images/graemlins/wink.gif Anyway, I was pondering modding a 5 LED flasher with those 7,500 mcd 60 degree 10 mm LEDs.
The 5mm LEDs put out 1,500 mcd max with the 10mm jobs putting out 5 times that. Granted, the forward voltage of the big'uns is 2.4V to 3.1V Max so that could lead to some problems. Here is my concept.
Use a 5 LED flasher that runs on 2AA batteries and run lithiums to boost the voltage to 3.4V. This will help when riding in the cold and have a brighter light longer.
To help the flasher transistor, I epoxy a metal heatsink on it to assist in cooling. Solder the 10mm monsters in and test one of them with my mA meter to see if it pushes them to at least 20mA. They are rated for 30mA so I assume that I can change the resistor to get it to 25mA or so.
Has anyone messed with the large 10mm LEDs and does my concept have any merit? Lithium juiced 10mm 5 LED flashers sure would help when riding in the cold months. If that works, figure out how to slap a 123a lithium in it to save a few bucks.
Any help would be appreciated. /ubbthreads/images/graemlins/smile.gif
