vinsanity286
- Joined
- Dec 5, 2006
- Messages
- 184
Hi all,
This is my first attempt at making a light so go easy on me. You guys make it look easy:shakehead The body is made from brass and the heat sink is copper, as you can tell. I have temporarily made the head out of delrin and as such I did not put much time into making it fancy. I hope to replace it with copper but at the moment I do not feel I can produce quality internal threads in copper. For now the light is running direct drive, though I plan on making a two or three stage resistor pack. Or better yet, does anyone know where I can get some QTC? Anyways, on to the light.....
You can still smell the machinists blue.
[/IMG]
Using a hi cri xpg on a 10mm board from illumination supply. The optic is a tina-2 from Cutter. Don't have any proper wire so this will do for now. Still pulls ~.9 amps from a cell with 3.8v free load.
[/IMG]
Bottom of heat sink showing positive brass contact insulated in delrin. The positive wire is soldered to the brass contact and the negative wire is a friction fit between a slot cut in the delrin and the sink.
[video]
[/video]
Assembled light engine.
[/IMG]
Threaded into head. Dull, bent drill bit in dremel=sloppy holes
[/IMG]
Stainless ITP a3, the watchamacallit, Peak El Capitan QTC.
[/IMG]
Hopefully with time I can produce a better product. Comments/critisism always wealcome and again, thanks for watching.
Vin.
[video]
Vin.
