I just picked up my second Lenslight KO, this time I went all out and got the newest version with the new tail cap and LED for more power and better battery life. It will run 2.2hrs on high at 440 lumens and 80 hrs on low at 5-10 lumens, I have seen it listed between 5-10 lumens on low so I don't know which one for sure. On low its bright enough to do most things you would need in a power failure and I use low setting most of the time inside.
I am not expert on all the lingo used here I just buy what I think sounds like a good light and since I have been carrying the Aluminum KO for over a year I figured if they improved it that it must be great because my original one has never failed me. Here are some specs on the light.
1) High Impact Hardened Optical Glass Lenses – protects the LED from the toughest of conditions and diligently bends the light much like a magnifying glass to ensure maximum brightness, distance, and efficiency. But don't let the durability of a glass lens fool you, these lenses have been vigorously tested and designed to withstand excessive abuse while retaining optimal performance.
2) Patented Focusing Aspherical Lens System – This patented technology allows for a significant array of focusing options ranging from a flood to spot beam. This ensures that the perfect focus setting is available whether you are concentrating the light hundreds of yards away, or simply lighting up an object nearby.
3) Titanium 6AL-4V- domesticaly sourced aerospace grade titanium. DFARS certified.
4) McClicky Momentary Activation On/Off Switch – This reliable easy to use tailcap switch enables the LensLight Mini's 2-stage microprocessor to power the flashlight at either an efficient low setting or high output level for maximum brightness. Simply press down once for low setting, press again for high setting, or simply press all the way down for constant-on.
5) Light Emitting Diode –A premium exclusive high-tech, high-efficiency LED is used to emit astonishing power that is untouchable by any other light. This everlasting LED is sure to exert enough luminosity to stop any and everything in its track. Now that's what you call an LED!
6) Premium Grade O-Rings- LensLight Mini contains 6 strategically placed O-rings throughout the flashlight to seal and protect the lights internals from dust, moisture, and any other micro-substance that it may come in contact with. This ensures that the LensLight performs at maximum efficiency at all times and your investment last a lifetime.
7) 2X CR123 Batteries – powered using two CR123 or RCR123 batteries.
8) Titanium Pocket Clip
9) Delta Grip- Delta engraved grip pattern for rotary focus operation. This high grip texture is engraved on a high frequency 50,000RPM spindle, 4-Axis CNC mill. This ensures quality and precision depths for multi-directional grip.
10) Tailstand Backcap- Allowing the user to stand their LensLight facing up.
(2) CR123 or RCR123 Batteries
Patented Focusable Aspheric Lens System
Titanium 6AL4V Construction (domestic materials only)
2-Stage Clicky Tail Cap Switch (low: 5 lumens/high: 440 lumens)
High Tolerance American CNC Machining
Double Lens - high impact hardened glass
Chem-Kote Contacts and Heat sink
Aerospace Grade Thermal Potting and Flow Management
Weather Proof/Water Resistant
Premium Bin High CRI CREE XPG-2 LED
Fully Regulated Light Engine
here are a couple pics.
The first two pics are off there website I have not had a chance to take any other pics yet.
For comparison here is my Aluminum KO with a ti strike bezel. Note the tail cap on the aluminum light you can't tail stand it on there new lights once the get production going it will be on all there light or maybe a option
