djpark
Peter,
As I start using ARC-AA, I find the following 2 (minor) problems.
1) It is very difficult to turn the head (too much friction) to switch on or off. I tried the rubber & nylon lubricant, but didn't help.
Can you recommend any particular type or brand of grease I can use?
2) After inserting the battery, the head desn't go in deep enough (IMHO).
It goes down just enough to hide the o-ring. The o-ring can be seen from the side angle when the light is on. I feel that it should go 3/4 or 1 mm deeper.
When I tried to turn it more, it actually pressed and squeezed the battery making it out of shape.
I suspect that the negative battery contact point at the bottom of the casing is too high. (or is it actually?)
I am thinking of removing some heights from the positive battery contact using soldering iron as suggested in your DIY thread, but wonder if it would affect the warranty in any way.
DJP
DJP
