I've bought a cheap ultrafire e17 to play with, it's a xm-l T6 with a aspheric (I think) lens that can be moved in/out for flood or spot. What I want to do with it is mount it on a rifle for lamping at night, I've already tried it and it's o.k. to 150yds. I'd like the spot to be slightly smaller but I can live with how it is - what I do need though is more light beyond 150yds. 200 or more would be ideal.
It uses 1x 18650 battery or 3 x AAAs
I'd like to modify this torch to suit my needs as well as possible without spending too much, I've not measured the lens or driver yet. I'm not too worried about the battery lasting for ages, I can carry spares (got some 5000mAh batteries on the way) and the torch is only on for short periods of time (30-60 seconds at the most usually) so I'm not overly concerned about heat. What would you recommend?
