I went to test 4 Eneloop AAAs that I'd charged a couple of days earlier. When I put them in, the charger said FULL. When I clicked to Test, it charged at an indicated 500ma for 90 minutes! At first I was alarmed, but the voltage was only 1.42 and an infrared thermometer showed that they were at 90F, the same as cells with plenty of capacity yet to be charged.
This seeming overcharging has happened with cells that weren't Eneloops, both on Charge and Test. They stay at a normal temperature and register full when the voltage finally reaches 1.52 or so.
I don't believe they're really being fed the 500ma indicated. I wonder if under some circumstances (for example to top off for a test or when a cell that isn't charged gets too warm) the charger reduces current by narrowing the pulses, but the readout reads as if the pulses were still full-width.
