justanotherguy
- Joined
- Sep 8, 2008
- Messages
- 522
$140 shipped USA
http://rs604.pbsrc.com/albums/tt121...9_151144_zpse96fbc41.jpg~320x480?t=1388353685
(Having problems uploading pics to the internet right now, sorry)
Some notes from the seller I got this from:
The modes are High > Med > Low > back to high.
Last mode memory off.
Blink warning for low voltage.
These dropins do not feature thermal protection. Do not run unattended. You *must* heat sink the dropin into the host properly.
Also supposedly not polarity protected , be careful!!!
High is approx 1,100 lumens out the front. Med is approx 400 lumens. Low is approx 15 lumens. At 5.6 amps it has a draw down from 1,100 --> 20 lumens spanning 1 hour 15 minutes on a single 3400mAh 18650. 2 hours and 30 minutes with 550 lumens.
1X18650 ONLY. Do not use multiple cells.
Quite a drop-in in a small light! I use it in a 26650 host though, from fivemega.
I have one optic, and cannot find the other at the moment. When I do, it will go to the buyer.
Thanks
Tony
Thanks
Tony
