Just ordered 2 of these off local auction site. I Was wanting to know a way to make these brighter. I didn't know if you guys could recommend different led or something. Also wondering how good of a deal I got. 2 of them brand new for $100. Thanks.
Well there's a few options. To keep it simple you could use this LED drop in, Malkoff Devices MD10. If you would like to keep using an incandescent lamp then this is where is gets more complicated. First you will need two high quality 17500 Li-ion cells such as then ones sold by AW, a high quality Li-ion charger and either of these lamps. Lumens Factory HO-M3 or EO-M3.
There is one other LED drop in but it's slipping my mind at the moment.
Ok I got another m952v I'm looking at that is 150 lumens. For $200.
What at would that mall off drop in make the Lumens on the m952xm07? And how much does that cost. I think I can get that light for around $70
You should have no problem selling the other two lights at a reasonable price.
Is this thread discussing the M952 or the M962? The above Malkoff link is for an LED assembly seems to be intended for the M962 light. Maybe there's a difference between the M951 and M952 that I'm not aware of.
The stock Surefire LU60 collar works reasonably well with Malkoff's M60 and M61 series of engines. I recently bought an Oveready LU60 for use with my M951, and it fits the M61 very well.
i need to know where to find a led upgrade and how to do it for a m952xm07.
Ok so it's around $40 for the over ready then 20-80 for a good p60 led. Is this correct? Also, wanting to know a good asking price for a brand new m952xm07 stock. I have 4 of them and will only be upgrading one.
I just know I want it to be brighter (65 lumens) going off of reviews I have read and watched. Id like it to be bright if it were Ever used at night. I would probably want in between floody light and a straight beam. This is not for a home defense weapon so really just bright enough for outside. So I don't think it can be TOO bright.
Different out puts would be nice but not completely necessary.
So any more combos or suggestions would be greatly appreciated.
Locating one that's brighter than 65 lumens won't be a problem. The ones I've mentioned range from 325 (Malkoff M61 cool XP-G2 version) to 700-ish (Nailbender neutral XM-L2). Compared to a P61, the Malkoff is damn bright, and the Nailbender XM-L2 is simply unreal.
Since you're looking for a flood/throw combination, you'll want to choose an Orange Peel reflector, sometimes referred as OP.
The Nailbenders have a deeper reflector than Malkoff, so they produce a smaller diameter spill light area and significantly brighter hot spot. My only Vinh is a reflectorless mule, so not comparable. The beamshots I've seen lead me to believe they will be similar to Nailbender's.
Here's a thread from last year in which I helped someone choose a drop-in http://www.candlepowerforums.com/vb...commendation-for-P60-drop-in-for-weapon-light. You may find the information in it useful.
I've fired countless rounds with various Malkoffs attached to 7.62X51 semi-auto rifles and a 12 gauge shotgun. I've also personally tested my two Nailbenders on the shotgun, and trust them completely.
I agree that for outdoor use, it really isn't possible to have too much output. I've decided that my primary outdoor AR should use the Nailbender XM-L2. The massive output and deep reflector (though really not that massive when compared with MT-G2 and SS-50/90s) allows it to deliver significantly more light on target at 100 yards than my brightest Malkoff M61 SHO.
Yes. There aren't that many current drop-ins available that output less than 100 lumens.
As long as the electronics are sealed with epoxy (potted), the LED assembly should be basically recoil proof.
