Wylie
All this talk of the Lux3 123 gig has me going on something I am calling the Wycan. I haven't got the Habor Freight flashlights in the mail yet but I thought I would try and get a head start on fitting a TVOK/MMWO sandwich in one. The over all outside diameter of the compression nut is .705" and the height is about .463" from the positive contact to the top of the compression union nut. Do you think she's going to fit?
Okay here's the skinny, the aluminum ring is from an Oracle PR base that I cut a thin slice from and sanded very flat with a diamond type knife sharpening stone. The reason it has been Artic Aluminaed in place is the brass didn't have a flat enough surface for me and I want make sure as much contact as possible is made with the sandwiches sink. I did use some foam up against the aluminum as to not mar the surface I prepared when I epoxied the parts together. The threads have been ground out of the compression nut and the .592 o.d. .014 wall thickness brass tubing slides in nice and tight but will release easily. The sandwiches potting has been adapted to fit into the brass tubing real tightly with the use of epoxy putty and this also helps to center the sandwich when used in an AA flashlight. The sandwich can still be used in other flashlights just slip the collar off and it;s like nothing ever happened. /ubbthreads/images/graemlins/grin.gif
The Frean optics fit into the hole at the top of the compression nut with enough spare space to allow for twist on/off operation. /ubbthreads/images/graemlins/thumbsup.gif
What I plan on doing with the Harbor Freight flashlight is to move the brass lamp holder all the way to the front of the battery cylinder and cut the raised area away. After cutting the raised area away I am going to grind a larger hole in the now ex-lamp base that will be slightly larger then the optics athough following the contour of the optics again to allow for twist on/off operation as well as the clicky on the rear of the flashlight.
I imagine I will have to grind some of the edges from the compression nut but it is very close to the right size so this shouldn't be too bad. I don't consider the connection of the points on the compression nut all that important as the heat sinking will go through the aluminum ring to the brass compression nut and onto the ex-lamp holder as I will press these two together very tightly.
EDIT: So do you think she is going to fit or is it really that bad? Please give me some feed back I'd like to know what you think good or bad.
