Hi gurus,
I had an M61w installed in a Surefire 6P bored to accept 18650. I am running an AW18650 2200 mah since I had quite a lot of 2200 mah and don't know what to do with them. It was working fine just a few days ago but last night I was surprised to see the light not working at all and so I did a battery check only to realize that the battery has been drained to 0.005 volt.
I can't be too certain if I did really switch off the light before placing it bezel down on my wooden shelf. I usually have the habit to check and ensure that the lights off, but I may have missed out on that.
So here's my questions...
Is it possible for a protected 18650 to drain down to such minuscule amount like 0.005 volt? Is the battery spoilt, and if it's not, would this low drain damage the battery at all? Last night I placed it into the Nitecore i4 Intellicharger and it has been 9 hours since and still charging.
Do you guys think that I left my light on when I placed it bezel down on the shelf? If I did, I don't see any damage on the shelf nor the finishing that was supposedly created by the heat buildup. Would there be enough heat generated by the M61w to burn or bubble the finishing of the shelf at least?
Worst case scenario. Was there a slight short circuit somewhere that resulted in the parasitic drain of the battery, or is the battery age the cause of it? After all, the battery is about 4 or 5 years old and have yet to see much action. I did however use it once in a couple of months and charge it up.
I understand that the M61w was designed to taper down its output when the battery is weak, but does it have a protection cutoff when the battery is too weak?
Thank you guys!
Thank you guys!
