Bleeding away the excess heat from our beloved and inefficient LED-lights is vital, we all agree. There seems also a common agreement that a huge metal heatsink housed in a big aluminium chunk serving as a body will do the trick and you've done it, the perfect temperature-effective LED-light.
I dare say this is wrong, at least partially. Let me explain my heretic thoughts:
We can agree on the huge heatsink on which the emitter is to be mounted. This is a necessity for quick heat removal. On the heavy body we disagree. A huge mass of metal can absorb heat nicely, at least in the case of aluminium. But when heated up, the efficiency of this heatsinking will suffer greatly.
IMHO the most important part in heatsinking is a good path for the thermal energy from the LED to the heatsink to the body and from there on ... to the air or flesh. A heavy body can offer temporary relief for short runtime applications, but will be useless for longer burn, or let me put it better: the big chunk will be just as effective as thin tube of the same size in thermal relief.
For this thermal relief there are basically two pathways: transfer the heat to the air by increasing the contact surface, e.g. with cooling fins, knurling etc. ... or ... transfer the heat to the human body by maxing out the contact surface, too, but with the opposite solution: by making it smooth.
Anyway, for long-run applications the deciding factor is heat removal from the flashlight to the surroundings, a thick massive body is not really necessary to accomplish this, the most important thing would be a good pathway from the LED via a heatsink to the body and away from it quickly, much quicker than with a short-burst-style light that can take its time bleeding away the heat from the thick and hot body.
Conclusion:
Short runtime applications would benefit from a thick body as a "thermal energy buffer"-heatsink whereas long runtime applications would not need a thick body since they must be able to bleed away all the heat that is created in the same time, and the limiting factor is not the aluminium body but the transfer from the body to the surroundings. Those lights should be built differently then and could be noticably lighter and smaller.
Just had to voice my thoughts regardless of my technical ignorance and stupidity /ubbthreads/images/graemlins/grin.gif, thanx for reading.
bernhard
Conclusion:
bernhard
