[OPEN]
[SOLD] Smoothy, Optic-FOV 25, XML2 5k, KD 1520, 123 size, LMH, N Memory, $55 + accessories.
Available to Buy right now:
(1) HD Bezel, 25 degree, XML2 6000K, 1520ma, 123 size, LMH, N Memory, $55 + accessories.
(1) Smoothy, 25 degree, N219, KD 1520, 123 size, LMH, N Memory, $55 + accessories.
Hi Folks,
I'm ready to open the second Copperhead wave.
Here is the first wave with lots of build info.
In Summary, the Copperhead is a very tough, small light based on a c-thread extension tube, and made mostly of copper otherwise. It starts with a solid copper slug. On that, I reflow a copper sinkpad, and then the LED emitter. By itself, this heatsink can take direct drive from an 18650 for quite a few minutes through a Nichia 219.
The driver is wired up with 22g silver plated stranded mil-spec teflon wire, and encased in mil-spec structural epoxy filled with pharmacy grade zinc oxide for thermal transfer, then the whole pill is wrapped in copper tape.
This pill is friction fit into a copper tube and secured with more thermal epoxy. a TIR is mounted and secured with thermal epoxy, and a copper cap is fitted over the front with more thermal epoxy. Finally, this insert is pressed into the front of a Solarforce CR123 extension tube with approximately 1000 lbs of force and more thermal epoxy.
This is the result:
The parts:
I am completely open with this light. All parts are the highest quality that I could find and I will disclose everything.
Tube: Solarforce CR123 or 18650 extension
Copper tube and endcap: 3/4" Type M water supply pipe
Copper pill: 110 Copper Round Rod, ASTM B187
Driver: Kaidomain AMC7135 V2 LED Driver . Possible driver power is 1520ma or (XML only) 3040ma with 5ma low, or 3040 with 50ma low. I can boost the amperage up to 4560ma for an extra $20. It is no trouble to pop off 7135 chips, so if you would like a custom drive level below 3040ma, just let me know (no charge). This driver has over-discharge protection and will reduce power at 3.0v. It runs best with RCR123, 18350 or 18650. A CR123A will work fine but not drive it to full performance. I am working on a "battery vampire" driver that will work from 0.8 to 4.2v with 760ma output and will make prototypes with 35mm and 50mm lengths for cr123 and aa battery sizes.
PCB: 20mm copper sinkpad sourced from vestureofblood
LED: Nichia NVSL219AT-H1 4500K, 92 CRI, B10 Bin or Cree XM-L2, T6, 3C Tint (5000K) or 1C tint (6000K) sourced from Illumination Supply (other LEDs can be used of course)
Hookup wire: 22 AWG stranded wire with 19 strands of silver plated oxygen free copper wire with teflon insulation. The grounding wire is thick copper braid.
Lens: Acrylic TIR with available angles of 15 (Nichia only), 25, 45, or 60 degrees. These are nominal measurements only - see the first thread for actual beams.
http://www.candlepowerforums.com/vb...sales-thread&p=4302981&viewfull=1#post4302981
http://www.candlepowerforums.com/vb...sales-thread&p=4309885&viewfull=1#post4309885
Thermal Epoxy: System 3 T-88 Structural Epoxy (Used to make airplanes and boats) filled 1:1 with pharmacy-grade zinc oxide powder.
For Clarity:
$55 gets you what is in the first pic.
Add:
$5 for a basic solarforce switch (forward clicky)
$7 for a shrouded solarforce switch (forward clicky)
$7 for a basic solarforce switch (REVERSE clicky)
$9 for a shrouded solarforce switch (REVERSE clicky)
$5 for an additional 123 tube to make it 18650 compatible
$5 for a solarforce clip
$2 for me to grind off the lanyard loop from the clip
$20 for 4560ma driver
$2 to upgrade to the HD bezel (no longer available)
To Order:
Specifiy LED, Driver power and low level (5 or 50ma is available on the 3040 driver), tube size (18350 or 18650 size), bezel type (smoothy or HD), and accessories (Extra tube, switch, clip).
Available driver modes are found here.
True to the policies of the best CPF sellers, I will not ask for any funds until the product is ready, and will make right any problems.
Known Issues:
1) I am pretty slow - expect a couple of months while I source parts and work on these. I have a job and 3 kids.
2) The TIR does not produce a perfect beam. They work great as flashlights, but don't expect a smooth white wall beam. There are minor artifacts. These lenses were selected for their durability and waterproofing.
3) Don't expect perfect polished machining on the copper. The cap will have minor imperfections from manufacturing and handling before I ever get it, and I can't remove these. I sand and brush the finish to make it fairly smooth.
Thanks, Dan Slone (schizeckinosy)
Hi Folks,
This is the result:
The parts:
For Clarity:
Add:
To Order:
Known Issues:
