HighlanderNorth
Here's a thread I started about 1.5 years ago after doing a little test between 2 single 18650 lights of about the same size and with similar brightness specs. They are the Eagletac G25C2 and the Sunwayman T20CS. Both lights are roughly the same size and the both are advertised at around 770L(620-650 OTF). I put both of them on turbo, set each on its tail so the head is pointed to the ceiling, and let them run for a while. I noticed that the Eagletac G25C2 seemed to maintain a significantly lower temperature on the exterior of its head and body, whereas the Sunwayman T20CS seemed significantly hotter. It did get to a point to where the Eagletac leveled out and wouldnt get hotter and I am pretty sure the Sunwayman had reached its limit and wasnt getting hotter either.
At that time I assumed this meant that the Eagletac light was staying cooler because its thicker, more dense aluminum body was doing a better job of conducting its heat away from the core to the exterior and into the surrounding air. But a few people said the opposite was true. They stated that because the Sunwayman T20CS was getting significantly hotter, that meant that it was doing a better job, and the heat I was feeling was proof that it was pulling heat from its core outside to its exterior. They implied that the Eagletac was cooler because much of its internal heat was stuck inside the light, not being radiated outward to its body as efficiently as with the Sunwayman.
To me, both ideas had merit, and I couldnt decide which was correct and I dont have any way to reliably determine which is more accurate. Below is my original thread. I thought I'd ask a few people here to consider this conundrum and decide which light is likely doing better...........
http://www.candlepowerforums.com/vb...at-heat-retention-with-your-lights&highlight=
