Hello-
First post here!!!
I was hoping that someone could help me out or provide some advice for me. I'm trying to build custom piece of equipment for my lab using 12 3-up Cree XPE2 stars. I was considering running 4 strings in parallel with 3 stars on each string. I want to run 1Amp on each leg and this will put the potential somewhere around 10.2V per star or 30.6V per leg and on the system as a whole as the strings are "balanced".
So, total voltage =30.6V and total current = 4Amp
I also plan to run those 13 volt LSP LED shunt protectors from Bourns on each star so that if one goes out the whole string will not be down.
Bourns P/N LSP1300
My questions are the following: would putting a 1.1A fuse on each leg and powering the system at 4A with a 60V 5A DC power supply in CC mode be OK or do you think the strings will be imbalanced and LEDs or fuses will start blowing? Anyone have experience with the shunt protectors?
I'm trying to avoid buying four or more driver modules and don't have reflow solder equipment to make my own.
Thanks in advance for any advice?
First post here!!!
Bourns P/N LSP1300
