[ QUOTE ]
Mednanu said:
My TW4 ran in regulation for quite some time before it dropped out. It would then gradually dim until one time it wouldn't really turn on any more once the battery got too low ( it was kind of cool - you could see the individual chips on the luxeon just barely glowing once the battery got low ). Put in a fresh surefire and it was back up to blinding intensity.
The TW4's regulate surprising long for running on just one cell. While I didn't do any quantitative tests, I estimate that I would get between 45 and 55 minutes regulation time before it would drop into a lower output. I may have gotten so much time out of the battery because I didn't run it all at once, but used the flashlight for only a few minutes at a time, each time. I was thoroughly surprised by how much runtime I could get out of 1 CR123.
It also never got too hot to handle - it would get pretty darn toasty, but never so that it would actually be hard to hold from the heat.
I also compared it to my friend's full size L4 and there was really no significant difference in brightness when the batteries were fresh. My buddy simply got longer run times due to the extra cell. It truly was quite an impressive light - I HIGHLY recommend the little TW4 torches !
[/ QUOTE ]
It may have appeared to be in regulation to your eyes, but there's no way the KL4 was in regulation on 1-cell for 45-minutes. It's physically impossible, unless you got some sort of deformed KL4.
