Kenjii
- Joined
- Jan 28, 2013
- Messages
- 42
Trustfire T90-2 XP-G2@5A - 713 Kcd
Hello,
my second build and this one throws very far, too It was not easy to disassemble the flashlight as the head is completely glued.
The Trustfire T90-2 is huuuuuuge
Disassembled
I used a LCK 5A Driver. Here with an adapter made of brass.
I put in a 3mm-Plug for the anode
The driver is much too small for the pill so i used some hot glue to fix it.
I want to pott the driver, but the pill is that large. There has to be filled in a lot. Perhaps later after some testing.
The LED on the massive heatsink which is in one piece. I used a Noctigon XP-G2 R5 2B dedomed.
The LED in the reflector
There is still some work to do. I think the LED is noch deep enough in the reflector, so there may be some losses. The Lens ist not very good etc.
A first Lux measurement at 6 metres was 17280 Lux. That is calculated back to 1 metre
622080 Lux @1m / Kcd or 1577 metres Range.
For the first try very good. My initial aim was to achieve 600-700 KLux and i am very happy to be that close.
Two Beamshots about 250metres, 3 Sec., F=4,5, ISO400
Thanks for reading and greetings from Germany
Kenjii
Hello,
Disassembled
Kenjii
