Labrador72
It doesn't look like a budget or basic light anymore http://www.jetbeamlight.com/ShowProducts.asp?ID=50
I don't have my box lying around, but I think the stepdown time is the same as the older version. Five minutes I believe. I haven't run it in that long if a period to notice the stepdown yet so I can't comment on the brightness perception. It shouldn't be that bad, I'd guess around 500?
My my only complaint, although minor, is that the pocket clip lip rests close to the head so it might be a bit difficult when placing in a pocket as the clearence is small. Not bad and I can put it in if I hold the pant pocket stiff. As I mentioned earlier, the 800 lumens did not seem as close as the 820 lumen xt11, but it is still plenty bright. The build quality seems good enough and the interface really is simple. The 100 lumen low mode is a good level for general use. Has the right amount of light to light indoors, but too much of course for up close stuff like reading.
At first turn on in high, the tint seems a bit purple, but after a few seconds my eyes see a white tint. It's not neutral but comes off more white than the xt11. Good for me as I'm shying away from bluish/purple tints. The BC25 has pretty good color rendition making a good choice for interior searching.
Weird I didn't even noticed that the first time^I like it too. They show two different versions on their website. Both are good, just curious which tailcap it will actually ship with:
I always recommend Eagletac 18650"sAnyone? Can someone please tell me a good 18650 to use in a BC-25. All I've ever used are a couple SF123A's in my current BC-25. It's confusing for this 75 yr. old fart! Flat tops, button tops, protected/unprotected, varying length/diameters, etc. The only re-chargeables I've ever used are AW 16340's in my single cell lights! I'm sure there are some Jetbeam BC-25 owners out there; what works best for you? Thanks
