Klarus
Page 168 of 168 FirstFirst ... 68118158161162163164165166167168
Results 5,011 to 5,020 of 5020
Thread: WTS - FDT (Flashlight Deals Today)
  1. #5011
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    Default Re: WTS - FDT (Flashlight Deals Today)
    Quote Originally Posted by SKV89 View Post
    I had some time to play with the X80GTvn and I absolutely love it. I was taken by surprise how tiny and light weight it is. It is quite a bit smaller and lighter than the MF01S, which is already a compact pop can light. Considering how small and light weight it is, I'm surprised this thing can handle high output for so long. I guess having alot of high bin (high efficiency) emitters keeps the current to each very low allowing them to run at high efficiency so less heat created. The thing is like a mule, everything in close distance around you becomes painted in pure white light. I never seen anything like it. It's the type of light you would want if you were to enter a dense forest with tall trees as the flood will illuminate the entire scene beyond your peripheral vision and I don't notice any green, blue, or magenta; just pure sheet of white. Is also excellent for large indoor spaces where it lights up everything and absolutely no hotspot to cause overexposure when taking photos. Too bad there's no high cri version.
    Using the Texas Ace lumen top calibrated with Maukka lights, I measured 28,800 turn-on lumens using VTC6 button top, Acebeam Protected Cell, and VTC5D with solder blob so looks like that's the max this light will go. Using Sanyo NCR18650GA unprotected button top results in 25,430 turn-on lumens. However lumen tubes always favor throw lights over flood. For example, removing optics in a FW3A to create a 180deg mule will result in about the same output measurement as with optic despite the optic theoretically reduces output by 15% or so. Therefore I think actual lumen at turn-on is more like 31-32k lumens.
    Here are photometric measurements at moonlight mode:
    CCT: 6278K
    DUV: 0.0057 (above the BBL therefore greenish tint)
    Ra (CRI): 70.9
    R9: -30.8
    Rf: 68
    Rg: 94
    Ra: 70.9
    Here are photometric measurements at highest turbo mode:
    CCT: 6665K
    DUV: -0.0013 (below the BBL therefore clean attractive pure white)
    Ra (CRI): 70.9
    R9: -30.8
    Rf: 68
    Rg: 94
    Ra: 70.9
    Btw, the spring bypass in the battery carrier is the best spring bypass soldering I've seen
    Edit: Vinh, is there anyway you can put some HI CRI emitters in there? I would love to get one with 4000K to 5700K HI CRI emitters. BLFers discovered a new 95CRI emitter and is hosting a group buy for it. Would this require a whole new mcpcb or can you somehow get them to flow onto the current mcpcb? Maybe you might want to get one to see if it's suitable for your mods.
    Great report SKV! You've basically had the same reaction to this light as I did. Thanks for your photometric measurements too.
  2. #5012
    Feb 2007
    Arizona
    Quote Originally Posted by vinhnguyen54 View Post
    • D18vn Sand
    • Display light
    • Mint Condition
    • PHC Bezel
    • Red MCPCB exposed
    • Optics glued in place
    • White 2 6500K
    • $287 Value
    $220
    Vinh talked me into this. PayPal Sent.
  3. #5013
    Quote Originally Posted by Patriot View Post
    Cant be disappointed.
    I am happy to realize how happy I am. Thus, a chain reaction of happiness.
    SkyLumen54@gmail.com
  4. #5014
    Feb 2007
    Arizona
    Oh, definitely not disappointed! Didnít mean for it to sound that way. 😄. Just saying that I fell for another spectacular V54 light!😎👍🏻
  5. #5015
    ONE-OFF Surefire 6Pvn P60 Lego Host
    $ 90.00
    • Couple units available
    • Surefire 6P Body bored for 18650
    • Aftermarket head & tail
    • Xeno Black stainless bezel
    • Dual side AR coated glass
    • GITD front O ring
    • Heavy duty GITD green boot
    • FS54
    • Low profile grip ring
  6. #5016
    ONE-OFF Klarus Mi7vn Titanium - Classy Ti EDC
    $ 150.00
  7. #5017
    ONE-OFF D4Svn Supercharged
    $ 130.00
    • White2 6500K
    • Bump from 4600L to 5000L
    • Bump from 100Kcd to 118Kcd
    • Stainless AHC bezel
    • Polished after the Abrasion for smooth touch
    • Front glass eliminator
  8. #5018
    Feb 2007
    Arizona
    Uhhh.... that might just be the prettiest ACH finish I've seen yet! I mean, those purple/reds in that top pic are incredible!
  9. #5019
    Last 2 EC60vn
    You pick XHP35 HI 6500K or 5000K
    $105 Shipped USA
  10. #5020
    K75vn with a small factory power bump
    Sky Lumen Warranty
    Testing Sample
    MINT
    $290 Shipped USA
