Hey guys and gals!
I just wanted to share a few pics of a light I picked up yesterday at a local Wall-mart.
It's a single AA cell light from Bushnell that I presume was released recently. The name is the TRKR T125L (rolls right off the tongue).
Here it is next to some classic Fenix lights.
SHINY! It has 3 red leds as well as 3 leds that emit a purplish bluish light as you will see below.
I like this light a lot. The tailcap however.... is pretty cheap and flimsy and nothing like a Fenix tailcap.
It feels like eventually this would be the weak point on this light. With regular use it should last a long time though.
It's not horrible but definitely feels more mushy compared to the firm TK11 (and I've used the TK11 every day for a year).
Not sure what the main led is. Maybe someone can guess.
TK11 xp-g R5 on Left - Bushnell TRKR T125L on right. The Bushnell is rated at 125 lumens for 50 minutes.
I've adjusted the exposure so the TK11 hotspot is just barely blown out.
The Bushnell is actually quite powerful for a 20 dollar light. Much brighter than this beam shot implies.
A fun light overall and the main beam is actually VERY nice for the price. Warmer than the TK11 R5 though obviously not nearly as bright. The TK11 is 258 lumens while this light is supposedly 125. The rating seems fairly accurate just based off of comparing it to a few of my lights. The lens is plastic and there is a particle or two of dust on the underside of the lens. No biggie though. Doesn't affect beam.
The body is aluminum and sturdy enough, but when compared directly to the TK11 the TK11 truly lives up to the "Tank" name. If I took a hammer to the TK11 it would probably keep going. I don't think this light would do as well under extreme abuse. Everything is relative though and this light should be fine unless you purposefully damage it. There is a decent pocket clip on the light too.
You get to the red and blue beams by clicking the light on and off quickly. The order is main white beam, red beam, then blue beam. It seems to reset to the main beam if you turn the light off and wait a few seconds. The red beam throws maybe 10 feet while the blue light seems very diffused and is only good for lighting up things a few feet in front of you in a dark room. No, there is no awesome 3 color strobe.... *sniff*
I'll either throw a spare Eneloop in it after finishing off the AA Duracell it came with or put a Lithium AA in it and use it somewhere as another emergency light.
