Hey all,
I have an older Surefire 3V weaponlight which utilizes what I believe is the L30 bezel. I'm not all that crazy about lumen output but 20 lumens I feel is just unacceptable and I would like to upgrade to LED if possible. I know I probably have several options including using a new bezel but I really want to retain the classic look. I believe the main issue is that the bezel is the shock-isolated type which makes simple LED drop-ins a problem.
I was wondering what options do I have? I was looking at the Malkoff M31 which apparently is designed for 3V systems but I don't know if it will work and remain durable in an L30. Would I need to pull out the foam shock-isolating components and replace it with some kind of spacer?
Thanks!
Thanks!
