15.6 volts bulb
bdl666
Massachusetts
I have a Craftman drill flashlight combo and need the lightbulb for the light. I called sears and they have to order it.But sice it is a kripton pr base buld I'm sure that someone here might know were to get it.
Any ideas?
jhereg
Land of Oz (Dorothy, Toto,...
I think I have seen one on the shelves at Sears here. (Illinois) I looked at it briefly & decided there wasn't anything I really wanted to do with a bulb of that voltage.
Andy
RussH
MS
My local Home Depot has 14v bulbs which you can overdrive. A friend has his flashlight setup to run these with 6 of the CR123, 3V lithiums. It probably runs at around 16v with the .75 amp (or is it .85a?) krypton bulb. I use the 12v bulbs @13.8v using 5 CR123s. You might also try Radio Shack but my local one doesn't stock any of the higher voltage bulbs. -RussH
