I am not sure how many of you own this light, and I have emailed the manufacturer about it, but would like to see if those of you who have this light have seen this problem. I bought it sometime last year through the custom light section of this forum, and when I adjust the brightness on it, the light will flicker inconsistently unless I have the head tightened all the way at full brightness. If it is at full brightness and I slowly turn the head to dim it, it will at first, get a little brighter, then start to dim. Sometimes if I leave it at one of the dimmer settings, the light will flicker and will start to flash brighter and dimmer. It will sometimes do this if I hit the side of the light with the palm of my hand. Is there a way to clean or lubricate the piston that controls the brightness? Also, the dimming control is very "coarse" and it is difficult to set it at any given level. Just barely turning the head puts it in high and barely on mode! Is there any way to adjust that? I have barely used the light since I got it. It was untouched for several months before I took it out yesterday to turn it on and noticed all of this. This may just be the way it works, but I was considering selling it and just want to be sure it is OK before I do so. Thank you to anybody that can be of any help!
