reviewum
Hello Everyone,
My good friend Doug Owen is letting me borrow his light meter to run some tests. I've been searching like crazy and can't find any info on standards on how to make measurements. Here are my questions:
1) How do I properly measure the viewing angle of an LED? Do I do so from the die or from the tip of the casing?
2) On LEDs that have multiple areas of brightness in the "pattern" (dark in the middle, then bright, then dark, then bright) where do I start / stop my viewing angle measurement?
3) What is the most efficient and then the easiest (but relatively accurate) way to measure viewing angle? Using a protractor lying on a flat surface, or with a throw against a wall and measuring distances and doing some geometry?
4) When measuring brightness how far away from the meter / wall should the LED be? 12 Inches? 12 Feet?
5) My LEDs all have an MCD rating on them (I'm pretty sure that is the average rating within the viewing angle?). This meter has LUX and FC on it. How should I convert between the two, and also a regular candela?
I'm guessing this has all been asked before, but I can't find it anywhere. I would love to compile any and all answers to this on my website for others to read and learn.
Thanks in advance!
Thanks in advance!
